Ruckus R310
  • Ruckus R310
    Ruckus R310
End of Life
Product Detail
The ZoneFlex R310 is the industry’s lowest cost enterprise class 802.11ac access point. The R310 has dual radios (2.4GHz & 5GHz) which are capable of concurrent operation. It is a 2x2:2 stream access point, offering up to 867Mbps of physical layer throughput in the 802.11 a/n/ac 5GHz range, with an additional 300Mbps physical layer throughput in the 802.11 b/g/n 2.4 GHz range. It has a single Gigabit Ethernet port and can be powered by 802.3af PoE or a 12V DC power supply. The R310 has a compact form factor (13.8cm x 13.5cm x 3.3cm) is extremely helpful in easy installation, and enables the power of 802.11ac literally in the palm of your hand.
It is perfect for low client density deployments such as coffee shops, convenience stores and other brick & mortar establishments, where cutting edge WiFi is necessary, but there is only a lean IT staff to manage the network. The R310 is a perfect entry level enterprise class 802.11ac access point that delivers maximum value at minimal cost.
Model Name:
R310
Product Family:
EOL RUCKUS Products
Recommended Software:
Stability Release:
Patches:
SmartZone AP Refresh Patch 5.2.2 (LT-GD MR 2)
Technology Release:
Patches:
SmartZone AP Patch 6.1.0.0.9240 (LT-GA)
Documents
Downloads
KB Articles
Forum Topics
Security Bulletins
Support Bulletins
Advanced Search
Working...Please wait
This is here to prevent you from accidentally submitting twice.
The page will automatically refresh.
Alert!!
Close
