Ruckus H510
  • Ruckus H510
    Ruckus H510
End of Life
Product Detail
The ZoneFlex™ H510 is a Wave 2 802.11ac (MU-MIMO-capable) Wi-Fi access point with integrated switch in a wall-plate form factor.
H510 features Ruckus' patented BeamFlex + adaptive antenna technology to deliver high-speed 802.11ac WiFi in a low-profile design that can be discretely installed over a standard electrical junction box.  H510 allows a range of wired & wireless services to be delivered in hotel guest rooms, student residences, and multi-dwelling units with just a single cable pull per room and eliminates the need for additional switches and power supplies.
Equipped with four Ethernet ports for in-room access, the ZoneFlex H510 can be used to connect a range of wired network devices such as IPtv set top boxes, IP telephones, or networked minibars while simultaneously providing dual band 802.11ac wireelss LAN coverage.  An IEEE 802.3af-compliant Power-over-Ethernet (PoE) port on the H510 allows devices such as IP telephones to be powered directly from the wall switch.  The H510 itself may be powered via standard PoE or a DC power adapter.  The H510 can be deployed as a standalone device or centrally managed by SmartZone, ZoneDirector, or FlexMaster management platforms.
Model Name:
H510
Product Family:
EOL RUCKUS Products
Recommended Software:
Stability Release:
Patches:
SmartZone AP Refresh Patch 5.2.2 (LT-GD MR 2)
Technology Release:
Patches:
SmartZone AP Patch 6.1.2.0.1003 (LT-GD-AP Patch-1003)
Documents
Downloads
KB Articles
Forum Topics
Security Bulletins
Support Bulletins
Advanced Search
Working...Please wait
This is here to prevent you from accidentally submitting twice.
The page will automatically refresh.
Alert!!
Close
